Volt-6/8/10 Coaxials Assembly Tips & Info Thread
Discussion in 'Speaker Kit Information' started by Matt Grant, Dec 28, 2014.
  1. OK, I can increase the size of the enclosure by ~5% to make up for the shorter ports, if that makes sense?
  2. Yes you can if you want, but the slightly higher tuning is not much to be concerned about if you plan on crossing over at or above 80hz.
  3. Looking to do a volt10 as an inwall. Its only a 2x4 depth. Is this even feasible?
  4. No it's 5.5" deep so it won't fit in a 2x4 wall, even a 2x6 won't work with the Volt-10 without some kind of extra spacer. The only one that could possibly fit in a standard 2x4 wall is the Volt-6 but even then you need to add about 1" to the depth of the 2x4, say 1/2" for drywall + 1/2" baffle.
  5. Two somewhat related related questions.
    1) What is the minimum power I can apply to these and them still sound decent?
    2) Can anyone recommend a corresponding inexpensive USB amp to power them?
    I have a set of Volt 6s that I've only just now assembled after years of sitting on the shelf. They're intended for an ATMOS install, but until I get around to that, I'd like to use them for my desktop speakers. I'm running an iMAC, with no optical outputs, so rather than using several converters, I'd like to just use a small amp with a built in USB and DAC.
    Any suggestions are much appreciated!
  6. My basement finishing project just started. I bought six Volt 8's with the sealed flat pack boxes. Four are four Atmos in ceiling. The other two are going to be in wall surrounds. I have a few questions.
    1. I'm planning to stuff the boxes. The contractor will mount the boxes in the studs (12" centers, so the 10" boxes fit like a glove), and then do the drywall. How the heck to I get the stuffing in the boxes? Can I spray adhesive it in? Maybe stuff the boxes, they tissue paper over the hole. After the holes are cut in the drywall, then punch through? I'm really not looking forward to trying to stuff the boxes when they're in the ceiling. Hoping someone has already fought this battle.
    2. For the surrounds, I bought the sealed boxes. I'm curious if if should switch to ported enclosures. The sealed boxes will definitely fit. For ported boxes, I'll have enough depth on one wall for sure, but the other one is going to be just enough, or too short. Is it a huge deal if I stick with the sealed boxes?
  7. Hi Matt- Do you have any information you can provide about the new “Version 2” designs on the DIYSOUNDGROUP site? (Design goals, use recommendations, trade offs, etc).
    Looks like they include an upgraded compression driver. Do you have the full depth of these new units with this comp driver?
  8. 1: If you are using polyfill there will be enough friction to stay in the enclosure when upside down so you don't have to worry about it falling out. Same is true for most damping materials if cut large enough to touch the sides.
    2: Sealed boxes will do fine as surrounds, you may want to experiment with the crossover point as 100-120hz would likely be ideal for those but you can manually set them to 80hz as well.
  9. Updated posts on the first page with info for the new v2 Volts.
    SavageAudio and mtbdudex like this.
  10. I received my volt 10v2’s and am going to give a go at installing the extra capacitor needed for atmos in the small sealed enclosure. Looking at the pics on the first page I only see info for installing with the previous model crossover and not the version 2. I don’t want to mess this up ;) anything differently or even a video anywhere on this. I did buy the pre made crossovers so that parts done.
  11. All you need to do is connect the 400uF capacitor in series with the woofer, so attach one end of the capacitor to the positive side of the LF terminal block and the other end to the positive wire going to the woofer.
    Michael McAllister likes this.
  12. Matt, I've just ordered two of the new Volt 6s and intend building the angled enclosure however I intend to increase the width of the enclosure from 8" to 9" and increase the depth on one side only from 8"to 9" to give me the angle I need when used as rear surrounds.
    Do I need to change the stock port length and if so by how much?
  13. Pardon my ignorance but to just make sure, I just screw down the +LF terminal block on one end of the capacitor and then solder the other end of the capacitor to the speaker cable that runs to the + woofer wire?
  14. And hopefully this will be my last question, I have about a 1/4 of dynamat lined inside my cabinet. Is it necessary to use the spacers when mounting the crossover? I will need a bit longer screw if so to get through the dynamat.
  15. Yep that's it. If you have a version of Dynamat with the foil backing you need to make sure the crossover stays elevated off that surface. Or determine if it's electrically conductive or not, if it is the crossover connections will short out on the material.
    The tuning will go down slightly with the larger internal volume and stock port length but it should be fine to leave the port as is.
    Ringnut likes this.
  16. Wondering if you could make the sketch up files available for these? Would like to build 4 for in ceiling volt 6's.
    Curt
