ultimate home theater
Discussion in 'General Topics' started by yellowsky07, May 26, 2020.
  1. yellowsky07
    yellowsky07 New Member
    Hey guys , new to the forum. would appreciate opinions on the ultimate home theater system from seos speakers. thinking 1299 for fronts and 8 ht 12s for surrounds.also 4 ht tubas for bass?
  2. LuisV
    LuisV Well-Known Member
    I know you said SEOS, but if you have the room for the 1299s, I would go with the Titans. Not sure you need the HT 12s for surrounds as the HT 8s or 10s should be plenty, but it all depends on the size of the room.
  3. yellowsky07
    thank you luisV for your reply.didnt think about titans. Im leaning towards the titans and the
    LuisV likes this.
  4. yellowsky07
    opps ,the volt 10s for surrounds.not sure about mixing point source and waveguide speakers together? my basement room will be 31'×33'. so in your opinion, should I go with volt 10s or ht 10s? thanks.
  5. Matt Grant
    HT-10>Volt-10 in nearly all aspects except vertical dispersion which makes the Volt-10 better for use a atmos speakers.
    Paul Carlucci and LuisV like this.
