Volt 6 xover board
Discussion in 'DIY Speakers and Subwoofers' started by Jason Burchill, Jan 28, 2021.
  1. Jason Burchill
    Jason Burchill Well-Known Member
    Hello quick question, do you super glue the copper coil thing to the board, or just use zip ties. This is the first time i've ever done this. I'm sure I'll have more questions
    Thanks for the help
  2. Jason Burchill
    Nevermind, I found the video of where they glue it down. I knew there was a video, just needed to find it
  3. Jack H Toepfer
    Jack H Toepfer Active Member
    I glue everything to every board. It’s probably overkill, but while the glue is flowing it put it on every piece. I still zip tie too, when I can.
  4. Paul Carlucci
    Paul Carlucci Well-Known Member
    I hot glue everything and zip tie the things they have holes provided. Occasionally I'll have one of the hot glued things break free as the board gets jostled about so anything that helps hold stuff in place is a plus.
