4 cu ft Subwoofer Box Options
Discussion in 'Flat Packs and Assembly' started by noman74656, Dec 30, 2013.
  1. Hi All,
    I am planning on building a subwoofer out of the 4 cu ft in the near future. I'm wondering what recommendations people have for the configuration.
    I have settled on the Stereo Integrity 18" woofer, but what would be the best way to drive it? would the Bash 500W plate amp be a good fit? Does a plate amp even fit on the back of the sub with the way the internal bracing of the box is setup?
  2. I would recommend a pro amp instead.
  3. Any particular reason? Or any particular amp you recommend??
  4. Try a inuke 3000DSP from parts-express.com
  5. I was thinking if I go with a pro amp that or the Crown XLS1500. Would either of those be more than enough for those 18" SI's?
