I bought a pair of Hitmaker kits at Erich's suggestion. Things are going along fine but I came up to two things I an unsure about. Thought I'd check here before proceeding. First, does the rear port go on the top or bottom? The rear panel could be flipped so I'm not 100% sure what is up or down. There are no pictures of the back - I guess it should be obvious but it isn't to me. Second, the port itself is adjustable but there is no information on adjusting it. Not sure what to do here. Suggestions would be much appreciated, Thanks.
From what I can see on Paul's write-up on the Hitmaker, the port goes on top and should be 6". Problems solved.
