HT-12 vs Fusion 15 in a larger enclosure
Discussion in 'DIY Speakers and Subwoofers' started by Ceedubbya, Sep 9, 2020.
  1. Ceedubbya
    Ceedubbya Member
    Hey all, I am interested in building a pair of DIYSG two-way waveguide speakers for mixed music/HT use. I would like to build them in a larger enclosure to boost low range performance and an looking for opinions on which speaker kit, and I guess woofer more specifically, would perform better in such a design. Ideas on the HT-12 vs Fusion 15 kits in a larger enclosure? I have seen the suggestions by Matt on the ideal size for each if going for a larger cab, but which do you expect will perform better? Also, anyone out there who has built either with a larger enclosure that can report on their performance?
  2. Matt Grant
    Fusion-15 wins in output just from it's greater displacement capability. I know a few on AVS forum have built them in larger tower enclosures with good results. I don't know if anyone had tried a larger enclosure for the HT-12 yet. The HT-12 won't require as large a volume as the Fusion-15 to reach the same f3 but it does start to run out of xmax much quicker if used fullrange in large boxes.
    Ceedubbya likes this.
  3. Ceedubbya
    Ceedubbya Member
    Perfect, just what I was looking for. Thanks for the input.
