HTM Speaker Kits
  1. #426 Kellen35, Apr 11, 2022
    Any news on htm-12 coming back in stock? Is it a crossover part that is missing?
    If so, any chance of getting a kit without the needed crossover part and me substituting it with something from PartExpress?
    I would also be open to running them on active crossovers as I have 8 channels of dsp and amplification equipment available. Long term I would rather use the passive crossover network but until everything comes back in stock this seems like a great option.
    I’m looking to do an LCR setup.
    MDuyck1292 likes this.
  2. Quick question...
    I've built a pair of HT-8s for Atmos heights. I installed terminal cups in two locations; one for if/when the speaker is ceiling or wall-mounted and a second for when the speaker is sitting on top of my fronts in an up-firing configuration.
    My question is if there are any issues with connecting both input terminals to the crossover simultaneously (only one would be in use at any given time).
    I'm assuming this is fine, but wanted to double-check.
    -Philip-
  3. It's perfectly fine to install two separate input terminals like that.
  4. Thanks Matt. Always appreciate how responsive you are to questions :).
  5. I put two sets of inputs on all my larger enclosures.
    One is a SpeakOn, the other is a normal binding post cup.
    The SpeakOn looks so small next to the binding post cup!
  6. Hi Matt - I was able to snag a trio of HTM-12s recently for my LCR. This was from the batch that was missing one inductor due to supply chain issues and they were sold with the caveat that this needed to be sourced separately. I'm referring to the "L3" 2.5mH iron core inductor which is missing. These are still difficult to come by, but it seems that air core 2.5mH 18AWG coils with similar 300 watt RMS rating are available for not much more. (See LW182-5 at Parts Express - it won't seem to allow me to post a link here).
    I realize the DCR varies slightly, but is there any reason why I should not just sub an air core for the missing coil? Also, would it be necessary to swap out both L3 and L4 for air core vs. the iron cores to remain consistent or is it ok to mix without concern?
    Andy
  7. Hi Andy you could use that air core if you really wanted to get those speakers going. It will reduce the output from the woofer by about 0.5dB in the upper bass/low midrange. You do not need to replace the other inductor with an air core. Just make sure when installing the air core that it sits oriented the same way as the I-core would have sat on the board.
    I should note that Erich has found a new source for I-core inductors and should be getting many of the popular values soon in which case you may be able to purchase one off him.
