Hi all, I was curious if anyone has any recommendations for mounting an HTM8 to the wall? There seem to be tons of mounting solutions on Amazon and was hoping to get this group’s perspective. thanks
If you just need it flat against the wall you can use one of the aluminum french cleat hangers (Hangman). Small flatscreen TV mounts also work well if you purchase one that supports the weight. Could also get the articulating mounts. Another simple solution would be to remove the drivers and drive two screws through the back of the speaker cabinet into a wall stud (assuming it's where you want to mount the speaker). This may be the most secure method. I would however use some kind of thin felt strips or something between the speaker and wall to prevent rattling.
