Anyone have advice on mounting Volt 8 Atmos flatpack speaker directly on ceiling? I don't have any attic space/access to install bracing for an in-ceiling look. Ceiling is 8ft so looking at relatively flat mounting. Best idea I have for now is using essentially swing hangers on both the speaker and ceiling and a through bolt to connect them.
Hi.... I don't have a clue how large of a distinction it would make, yet I would ascertain how much volume making the border more modest would remove from the crate, and afterward make the container somewhat more profound to counterbalance that change and keep the case a similar generally speaking inward volume. I don't have the foggiest idea about the real measurements you are working with here, so lets simply utilize the case of a case with inside elements of 8" x 8" x 5" profound. That case has an inside volume of 320 cubic inches. In the event that you made it 7.5" x 7.5" you would have to make it 5.7 inches deep to keep a similar inside volume. I'll allow the specialists to ring in, yet that is the means by which I would go with regards to it.
